Hey everyone,
I've noticed that with the colder temperatures around here lately (between -5 and 5 celsius), my 2.3i hasn't been performing as well as it should...
I noticed similar symptoms last fall and winter... When I start the car from cold, it's a little rough, but nothing too serious. The roughness tends to smooth out after about a minute or so. However, when I start off, my acceleration from a standstill isn't very good... in fact, it's almost as if the car has to "think about it" for half a second, and then it goes. Using fuel line antifreeze definitely helps with this, but my question is what to use? Methanol seems to work really well, but I've heard it's not good for fuel-injected cars. I've read that isopropyl alcohol is best, although it's more expensive than methanol. Of course, I assumed that all the petroleum companies here put antifreeze in their fuel already...
Any thoughts on what I can do to remedy this situation? (by the way, I always keep my tank at least 1/2 full, usually above 2/3).
cheers!
cheers!
