Been a long time since I've looked at the site - very impressed!
Anyway I have a problem that maybe very simple to work out -
The other day when the weather was hot I was stationary with the engine running and all of a sudden there was a loud pop from under the bonnet followed what appeared to be mist coming out under pressure. I stopped the engine & had a look under the bonnet and found some residue on the fan and top hose (bit like silicon grease spray) - I assumed it could have come from the air con. Air con / econ works fine but when I went to pick up my partner and new baby from hospital I couldn't change the heat setting unless the ACC runs on Hi - then its hot! Or too cold for the little fella - had a look under the bonnet again because I could hear some slight hissing and found a little rubber hose had blown off the top of the engine (LHS) - reconnected - no hiss - no warm air only cold or hot. Actually also noticed that the car stalled a few times since that little hose came off?!
Any ideas would be gratefully received so my new little boy can travel in comfort at the right temperature without arctic or sahara side effects!
9000 CSE 2.0 LPT 94 M
