I am replacing the clutch slave cylinder on my MY92 9000. I purchased a replacment from GSF.
It arrived without any bellows around the outside as the original has. I tried to fit the old bellows but was prevented by a plastic shroud held on by a large circlip. I removed the shroud and found the metal work underneath was similar to the old cylinder. So I fitted the bellows then tried to fit the thrust bearing. I can't get the bearing to hold the bellows compressed like the old one did.
Does the new cylinder with plastic shroud not require the bellows?
