hi, the clutch on the 9000 is hydraulic,
this means either your master cylinder , slave cyliner or your clutch hose is about to fail
check underside of flexi hose for fluid( its basically below the end of the throttle body) if you find fluid its probably the pipe because they are pourous if not its one of the cylinders
hopefully not the slave as its in the bell housing and to change is a gearbox out job
HTH
mark
