getting a weird clonking coming from the front of my 94 aero ..had a good squint underneath and pushed and rattled the usual suspects
symptoms
cobbles in linlithgow.. you get a metallic kind of rattling
edging in traffic jam (manchester) it clonks as you engage the clutch to move forward
engine mounts shot ?
its only done 190 k !
I had a same sort of thing. When engaging the clutch you get a kind of creek and if you brake hard and then take off again you get the creek. I have my engine mounts changed as they were shot (got a really heavy buzzing through the gearstick) but it didnt solve the creeking. I took it back to my loacal Saab Specialist and he knew what it was straight away. It was where the subframe bolts needed torquing up. Common he said and after he did this it was all sorted. Took about 1/2 and hour all in all..
HTH
ran the aero up on the ramps..
and yes there was a lot of bolts under there that needed tightening especially on the drivers side
did the cobble test ..result !!
happy man ..took all of 20 mins
got me thinking ..the 9000 must be quite "loose" around the front maybe a bit of judicious strengthening /buttressing would help the handling
The same probably started up with me today. I get a clunk when I engage the clutch, sometimes not all the time.
Would you recommend hand tightening it with out the proper torque settings, cuz my dad refuses to buy an $80 wrench (i don't have the money to do so)
If you do not have a torque wrench or you can't beg borrow or steal one then "good and snug" will be the best that you can do I guess. Are you sure that the engine mounts are in ok shape? as they can account for a clunk noise if worn.
