Can anyone tell me why on certain settings, regardless of exterior conditions, does my '96 cse2.3t mist up inside so quick. I can get rid of it by putting the de mist setting on but surely this shouldn't be happening should it?
Jon,
Is there a damp smell of coolant in the car is so it will be the heater matrix leaking.
Could be the recirculation valve stuck in the recirc position - search this board for more info. Could be a blocked drain in the filter housing - again search this board for more info.
Thanks to welshcaveman and Adrian for you very prompt answers to my Climate control problems,one other question for you both though:- Is there an easy way to find out if my matrix is leaking, I have done the preliminaries such as checking carpets etc.and if it is leaking what are the possible solutions.
Cheers chaps
Jon
