I own a 94 2.3t CSE with climate control. The trouble is that even with the temp set to 17c the cabin still gets unbearably warm. If I set it to LO then very cold air is blown in so I guess the air con is still OK. When I reduce the temp from higher (22c) the fan speed slows down but it still blows warm and eventually becomes to warm. I have reset the system and it does not come up with any error codes (ie the readout stays at '0') Any suggestions? (the interior sensor is spinning because I can hear it and the temp seems to drop briefly when you first reduce it)
