Hello again all.
I have a problem on the above-mentioned car.
When starting from cold i.e. if the car's not been used for 36-48 hours or so, the engine seems to only fire on 3 cylinders. It sounds really rough and goes...."Chug...chug...chug..."(!). After about 5-10 seconds, the problem clears and everthing is fine with engine running sweetly and no mis-firing at all. If the car is started on say, the next day after it has been previously used, she starts fine with no "chugs". However, if it's TWO days later or more, we get the above problem.
I have replaced the plugs with the correct NGK 7-11 jobs and replaced the DI cassette with a new one. All was fine until I had occasion to leave the car for a couple of days - then started her up...and...."chug...chug....etc"
There is no apparent leak from the head-gasket and no apparent coolant loss - I am baffled! Can anyone help?
Car is MY 97 Aero Manual (Black with Sand Beige Leather), totally standard with 69K.
