Hi ppl.
Yesterday (second day of owning 2.3CSE) the check engine light came on and stayed on.
Ive done the diagnostic test without starting the car and it flashes 3 times, which by my workigs out means the air intake temperture sensor.
Ive taken this info from and older tech doc, which is for an older car (trionic).
Does ne1 know if this error code is the same for all trionic systems? and is it a major cost?
Thanks all
Damian
I did not know you could make the check engine light flash codes. Could someone tell me if this is applicable to "94 and "95 9000's, and the proper procedure and the key(list) of codes and their corresponding meanings?
