Oh dear. Another problem.
I just fitted a new fuel pump, filter and relay two days ago. Had two days of fine motoring.
Now, as I was driving home the engine felt like it was losing power. I then noticed that the ‘check engine’ light was lit. I limped home and switched off and then turned on the ignition. The ‘check engine’ light flashes four times. After that I disconnected the battery for a while then reconnected, started up fine with no flashing lights. A while after that I went for a drive down the road and it started to display the same symptoms. Then the light came back on.
Since my car is a 1990 2.0 Turbo with Bosch LH with DI, (auto) I take it that this indicates that there is a problem with the knock sensor?
Where exactly is the knock sensor? I have looked in the Haynes manual but as usual was no use. (is there a decent shop manual for these cars?)
Anyway, does this sound like a dodgy knock sensor? Lack of power, threatening to stall on acceleration?
Starting to lose patience with this car.
Thanks, Billy.
Thanks, Billy.
