whoops, put some petrol in, and it mysteriously starts, must have run too low naughty me...
but... as for this 6 flash lambda thing, is it a garage job? how long should it take ?, or cost of part please ( if in fact it is lambda - car it a bit jump and low revs, low speed etc, and the DI unit, plugs, filter and oil all recently checked and OK )
thanks
Andy
Might not be the O2 sensor - there are a host of things that will give the CEL 6 flashes: fuel pressure (check the hoses that run from the FPR to the intake manifold, and from the MAP sensor), air leakage ahead of the O2 sensor (check the downpipe mounting bolts), and even letting the fuel tank run dry can set the thing off. Have someone hook an ISAT or TechII up, pull the codes, and go from there before replacing the O2 sensor - they're not cheap!
Check out that it isn't just a duff message. I got a MAP sensor error flash up - after disconnecting the battery to replace a clutch hose.
Disconnected negative again for 1/2 an hour (thanks to Mark E for the advice) and away went the problem. Cheap fix, worth a try...
