A couple of us are getting ideas together for a bit of a track toy. Car I'm thinking of is a T8 with an intercooler so it's the 155bhp model. The plan is to put it on an intensive weight loss programme to improve performance, but I wondered what suggestions you guys might have for getting more grunt from it.
We have an "interesting" exhaust already (though it might need a silencer to pass the noise regs ) Not too worried about driveability on the road.
What else can be done (very) cheaply? to safely get a bit more power?
For example, I'm aware of the possibility of bodging the cold start valve to create a 5th injector but not sure how to go about doing this. Also aware of using thicker washers between the APC knock sensor & the block, but not too keen on this one...
How about tweaking the APC box itself for more boost - worth it on a T8? Seems to have worked on nutcase's 99, but that's a low compression engine so not sure about this on a later engine. Are there any fuel pressure mods we could easily make and would this help?
Any other suggestions?
