I have all options on my 9000 console switches,can I get one with some switches blanked off (like the sunroof for instance)and put the switch from the old one to make it work.Are the connecters on the bottom different for different options?Any help will be appreciated.
the harness should be standard for all connections under the plate but if you get a switch block without the sunroof swich there isnt a blank you can push out to fit one
they only come with the holes for the window switches
HTH
mark
Thanks Mark,the one I'm looking at is blanked off on the switch to lock the doors.It comes from a MY93 9000,mine is a MY95.I would like to put the door lock switch in this one,will it work anyone?
