For anyone out there with a dead or dying central locking motor in the door, I've just fitted one from Maplin for a tenner which fits the existing screw holes and works perfectly.
It's probably what Haynes would call a one-spanner job, but as figuring out how to get the doortrim off is a two-spanner job, that shouldn't be a problem
Can be, but the interior lighting system is even more likely.
The boot (trunk) light can easily short out on the bodywork, its switch can too, the door "puddle lights" can get wet and short out and the light under the bonnet (hood) can short out, together with its switch, just by the radiator top.
The list is endless....
I suppose you could eliminate the central locking from the equation by disconnecting it, if anyone out there knows how to do it?
