Can anyone suggest a way of cleaning up the headlining [damp due to untraceable water ingress]. The car is of the road at the minute, I have many small jobs to do on her one involves rear section of exhaust, will a standard 9000 piece fit? I can refit the oval cover piece later. The clutch release bearing is very noisy now...is that a new clutch ass. that I need?? many thanks...Andy.
I find that the lining to the sunroof gets dirty and needs a clean from time to time. A spray cleaner "Mr Muscle for kitchens" (!) is very effective if sprayed and left for a couple of minutes before sponging off. This product also removes tobacco deposits if needed. Be sure to get the right cleaner tho` as an oven cleaner from the same manufacturer will probably remove the headlining as well.....
