Originally posted by stupot:
[qb]ok so suppose i decide to fit an mbc exactly what parts would i need or is it as simple as: 1 mbc and 1 boost guage. and how do i know which of the 3 pipes to insert it into, any advice would be appreciated as i am a complete novice, can i do it myself or would i need a pro to do it. [/qb][/b]
No pro required, just the gentle guiding hand of Saabscene . Seriously though, as with any mods you really should inform your insurance company, it's in the contract. If you didn't and have an accident and you get found out, then it's bye bye insurance, hello court.
OK talk over, on with it.
You can install the valve in several ways. This is the way mine is installed...
If the three hoses are pulled from the APC and the valve is attached then the maximum boost will be totally controlled by the valve. Find out which of the 'ports' on the valve you've bought allow the air to pass through freely with the valve fully shut. These ports should be attached to the hoses marked 'C'(compressor or turbo) and 'W' (wastegate). The boost pressure will now pass through the valve to the wastegate, showing the wastegate the actual pressure from the turbo. The wastegate will fully open at its' base boost setting with the valve fully shut. Now attach the third hose marked 'R' (recirculate?) to the third port on the valve. If the valve is opened a little the boost pressure will now flow through the 'R' pipe (back to the air intake) as well as to the wastegate , so less pressure is present at the wastegate then earlier, this makes the wastegate open less for a given amount of turbo pressure so more boost is present at the inlet manifold. Take the car for a spin (not literally now ) and adjust until you have the boost at the optimum level.
If a graduated boost gauge is inserted into the dash, use a three way tee piece to splice it into the pipe feeding the boost gauge on the instrument panel. Setting the boost to one bar (14.8 psi) is no problem as long as the rest of the engine is healthy. I've currently got my Aero set to 1.15 bar. However a with the head off at the moment it appears that the replacement gasket was only just in time, one more track day might have done it in.
Remember that the more
you have the more you are stressing all the other components of the engine, gearbox and drivetrain in general. Don't be surprised if a bit more
gives rise to a couple of extra bills in the long term.
Enjoy!
Nick.
