Hello all,
I'm having some real misfire/ stuttering issues when I accelerate. Once i get up to speed, it feels fine, it's just at low revs. sometimes theres a hint of a backfire
Ive replaced plugs, leads, distributor cap, rotor, checked for vacuum leaks.
I think it must be something to do with the carbs (although I'm open to other suggestions) I have replaced the diaphragms which were split and distorted.
Is anyone able to upload a picture of a set of twin stromberg 150 on a 900? Im sure I'm missing a bit from the side of one of my carbs, I'm not even sure what it's called. Its like a long piece of housing with a plastic top on it. I've attached a picture that I've just pulled from google, and circled the part I mean. What is it? and I'm guessing I should have it on both my carbs?
Any help would be greatly appreciated, I'm tearing my hair out!
Gas Camera accessory Machine Auto part Personal protective equipment
Discussion Starter · #2 ·
So, I now know they're temperature compensators. Would missing one of these cause the problems Ive described?
Sal_Gls,
Have you checked the oil in the dashpots ? This prevents the piston from rising too rapidly when you accelerate quickly. Since air moves more easily than petrol, this results in a very weak mixture for a few seconds and causes stuttering. The oil acts like a shock absorber and slows the rate of rise so that the mixture doesn't weaken. Use light oil rather than engine oil. Good old 3 in 1 is about right.
Paul @ Kippen
