Hello everyone! Help! My 2003 9-3's alarm keeps going off. I can not find it one the
car. I keep seeing people say it is under the driver's side front tire on most Saab's. Not
on this car. Please help... before I take a sledgehammer to the car.... the alarm just
randomly goes off.
Can you not pull the fuse? I guess it also depends which side of the car you drive from as to where 'driver's side front tyre' is
I think you will have to find the alarm module and check it out, batteries etc. It should be left side front wheel arch I think.
Or get someone to Tech 2 the car, that may reveal the cause
I did read you can set the alarm to go off on 'door only' and this for some people stops the random alerts from the other sensors
randomly goes off.
Most likely the battery on your alarm system is dying. This happened in my 9-5 and it is common. I had the alarm pulled. Consequently I get a notice on the SID when I start the car.
BlackSaab20039-3
The alarm is under the wheel arch liner on the left side ( facing forwards from the drivers seat ). As KJBillsBurg says, you can just disconnect it but you will get a message every time you start the car. Unlike the commonly felt belief that it is a dying rechargeable battery at fault, I think it is more likely that one or more of the capacitors in the alarm will need replaced. If you do a search there are threads with the values required and if you are OK with a soldering iron, it's fairly straightforward to replace them.
Some alarm boxes come apart reasonably easily, others need careful use of a hacksaw blade.
Paul @ Kippen.
