Well,
I finally got round to getting Bubbles on a reputable rolling road today... and it was quite interesting... a bit of tweaking with boost and we were able to get 290hp (corrected) at the flywheel... however it's difficult to drive like that as below 3500rpm it was too easy to run in to oversboost cut off. There's more I can do to sort this; reducing the preload on the actuator will help, although it's near it's minimum at the mo (it's a 12 psi spring),but it's all hassle...
So we settled for a "driveable" power of circa 270hp with a stomping great 330lbft of torque just above 3500rpm!! That equates to a peak boost of about 1.45bar, holding circa 1.25. Although the hybrid turbo really only spins up later, as you'll see from the graph below, there's over 260lbft available from about 2500rpm all the way to over 5000rpm. Why do I say 260? Well from memory that's the peak torque figure for a "standard" Aero to give a comparison. Torque is the upper curve, power the lower.
At the wheels today was a lower 215hp... but a standard scooby apparently only manages to get 150hp to the wheels!!
What more can I say other than
