Driving down the M3 yesterday and I noticed a vibration through the wheel Thinking I had shed a wheel balance weight I slowed down expecting it to go away. It didn't, it got much worse to the extent I decided to pull over.
I immediately noticed the left front wheel was smoking slightly so I removed the wheel and found the smoke coming from the grease round the axle nut. The caliper also appeared to be dragging and was very hot so I assumed a siezed caliper. 10 minutes later I went on my way (keeping my speed down) and it is behaving fine now.
I was going to change the caliper but thinking about it I am not so sure.
- The wheel bolts were at least as hot as the caliper
- the smoke was coming from the axle area, not the brake
- the wheel was difficult to turn but without and graunching or funny noises.
- no sign of slack in the suspension or bearing.
I'm suspicious that it appeared to be the hub that was hottest, not the disc, could all this point to a siezing wheel bearing rather than a siezed caliper?
