Hi
My 93 aero convertible 2005 is alerting me to rear right side brake light failure
However when I look, and someone puts the pedal down, I have a right brake light come on okay, but it is not in the same place as the one on the left car side
The two brake light areas I have circled in yellow
The left outer edge comes on and the right inner edge comes on.
Any ideas? Is it a dreaded earth issue?
Thx
Nick
52864
Maybe the dystem works like the Vauxhall Vectra C, where if a brake light bulb failed it would substitute a sidelight for the brake light so you still have a light each side. Check your bulbs and the holders for corrosion as that can cause light not to illuminate and appear to be a failed bulb.
Sent from my CLT-L29 using Tapatalk
Discussion Starter #3
Hi Thanks
Yes I just found much the same advice, the SAAB substitutes the tail light for the brake light when the brake light is bust and dims all tail lights at night so the 'brake' stands out. Very clever
So I think it is simply a failed bulb. So I've ordered one online as, of course, no car parts shops are open :-( MInd you I see no chance of my driving the car anywhere even with all lights working
I guess changing the bulb will count as my allowed 30 mins outside the house!
N
