1 - 12 of 12 Posts
Welcome to Saabscene, efcbluepete.
Haynes only specifies the minimum thickness after regrind, which is 23.5mm (they start out at 25mm). Presumably, they can be a bit thinner than this (they'll continue to wear after regrinding). Say 22mm at a guess?
Minimum pad thickness is 4mm.
Haynes only specifies the minimum thickness after regrind, which is 23.5mm (they start out at 25mm). Presumably, they can be a bit thinner than this (they'll continue to wear after regrinding). Say 22mm at a guess?[/b]
Haynes further confuses the issue by stating that a max of 1mm can be ground of each side.
The new discs I fitted last week say "Minimum thickness 23mm"
Originally posted by Derek:
[qb]Haynes further confuses the issue by stating that a max of 1mm can be ground of each side.[/qb][/b]
I presume that means that you can reduce the total thickness by 1.5mm, but can't take more than 1mm off either face. So 0.75mm off each side would be fine, as would 1mm off one side and 0.5mm off the other. However, 1.25mm off one side and 0.25mm off the other would be a no-no.
I'd forgotten that the discs usually have the minimum thickness stamped on the edge
Discussion Starter · #10 ·
Hmm, disks fine, pads fine... maybe I'm just used to my wife's 6 month old Honda (very easy to stop). Just feels like I am having to push too hard to stop/slow. Will take advice of other post regarding brake bleeding (wanted to do it today, but no time! Wil probably do it next weekend when I remove the broken exhaust manifold stud I found yesterday.)
Cheers,
Pete
I've also found many aftermarket discs to perform pretty poorly even with genuine pads. Not all discs are the same. For price/performance, I haven't found anything better than Brembo standard replacements. These are the same as Trent Saab sell with their "Group N" kit, but can be bought much more cheaply elsewhere (I bought the last lot from German & Swedish).
A set is going on my dad's 9000 shortly - I replaced the discs a year ago with cheap aftermarket items and the brakes have been really poor ever since. I should have known better - the same happened with my Aero a couple of years ago.
1 - 12 of 12 Posts
