1 - 12 of 12 Posts
I've just about sorted the route to take for the vacuum pipe (9000 BTW), and the electrics but I am having trouble with actually fitting the gauge into the pod.
I have attached a picture of the three items and cannot get them to fit. I assume that the little bracket (left of the picture) attaches to the boost gauge, then I believe secures the gauge in the pod. Could be wrong! Any suggestions?
Pod is the correct size BTW!
Scotty Mc - if you are using a pod then you can discard the U-shaped bracket - this is only used when mounting to a DIN panel or similar.
The gauge should just push into the pod.
You might find you need to put a layer or two of insulation tape around the front of the gauge to make it a snug push fit in to the pod- I have on mine.
Excellent stuff! It's just it came with the kit, I've lost the instructions and thought I'd best ask!
My Dad and I have opened our own discussion forum today, so to speak regarding wiring the gauge in. Any suggestions for the easiest and quickest way to wire it in?
I took my power from the back of the rheostat (just find whichever wire has voltage that changes with the rheostat position, took about 10 seconds with my digital voltmeter.
Hi all,
You may want to think about a different pod, I fitted this reasently as I wanted the un-cluttered look....just an idea.
The oil pressure gauge is going in this week!!!
http://groups.msn.com/_Secure/0TAAkA6cWSGKo*Q5ALVOQJyVsAUn*sQssHhCpzTjT2g2AOOQW1y9m1tIiwgNXHyTegq6IhGGAwDQOvOL
huSwuEOQdt4ICt4*X3sqSc!1T8t1qhhQ3fhtNg/Picture%20064.jpg?dc=4675494668750961007
Cheers Jim.
After 11 months wedged on top of the dash, the boost gauge finally got fitted properly. Thanks to Jim67 for the paint code, I agree, Ford cameo beige is a good match for 9-5 A-pillars! Halfords sell it too, I was amazed at the selection of beige car paints - must be a lot of grim looking vehicles out there
Hi SJ,
Glad I could be of help, the paint was a bit of a nightmare to be honest, I was saying it was beige I needed and my other half was saying "you must be colour blind its grey!!!" Like Luke Skywalker I let go my feelings and went for the beige!! but the touble is that that paint has such a slow turn-around on the shelves that the paint wouldnt spray right (leaking and dripping every where. Exchanged that can and the second was the same but managed to get 3 good coats on before I lobbed it at the dust bin !!!
Got to agree with you it is a [expletive deleted] colour for a car !!!!
Cheers Jim.
1 - 12 of 12 Posts
