Hi all. i just recieved my boost gauge, and I put it to work. Just as I expected- very low boost, around 6-7 psi. The car has been booked in Williams Saab for a check. With the solenoid disconnected, I get 5-5.5 psi. Isn't that a little low for base boost (6psi, I think)?
I have also ordered a dawes device. What boost levels are the rest of you running with such a device (or bleed valve)? Remember, the engine is completely stock. What is the stock boost level? 14 psi I think, but I may be wrong.
Harry
1992 CS Carlsson
6-7 psi
base boost sounds ok
In my car "normal" boost is about 1 bar or 14 psi
tnb boost is about 1.2-1.3 =17 psi ish
the fun killer comes in about 20 psi (with the bleed valve this happens occasionally )
interested how you get on with the dawes device
