I posted a while ago about my apparent lack off boost, car is 9-5 2.3 lpt running at stage 2.
currently getting 0.6 bar at WOT, this i'm told from many sources is low!
the software I'm running should give around 0.9bar.
So far I've:
Cleaned and lube'd the forge piston type BPV
Checked hoses, no apparent leaks as vacuum readings are ok
Checked actuator works, holds pressue etc.
Adjusted actuator rod, shortened 2 turns, with no change!
What next?
I'm thing boost control solenoid, they are cheap for T7 so I've ordered a new one... any futher ideas?
So far I've:
What next?
