My Saab 9000 CS with 146000 kilometers on the clock emits quite a large cloud of blue smoke on the first start each morning. After that the exhaust is clear.
I have been advised that the problem could be that overnight oil is leaking past the valve guides into the cylinders.
Not knowing Saab's very well, I don't know if the engines are prone to worn valves and guides, or whether new seals alone might fix the problem.
Has any member replaced the valve guide seals without removing the head?
