Good morning - all
Quick question, How do you check to see if your blow off valve is working correctly ?
Sometimes, I get a good amount of boost (ie, up in to the upper part of the gauge) Park the car for a hour or so - start out again, needle only goes about half way up, if I am lucky.
Replaced the vacumn lines with silicone lines - only one I didn't replace was the one that goes into and thru the aquarium. I know the bov bleeds excess boost back into the system, could it cause a low boost problem ?
