Help!
Arrghh. Please bear with me.. I don't know if all of this is related however :
The 9000 was running great boosting to 1.2bar @3000rpm.. trailing to 0.9bar @ 5000 rpm. It's boost was stable and only a whistling noise along with the growl of the engine could be heard. When I came of the throttle the boost gauge would show -0.7bar on the over run.. and at idle a very steady -0.5bar.
As of last night.. and today.
The 9000 has started to make an intermittent higher-pitched groaning noise when boosting.. at around 0.7bar... i.e as the car boosts .. at a certain point a very audable groaning noise is heard as the car boosts through 0.7 to 0.9 bar.. then it goes away again.. it does it on every acceleration and at every speed... and I don't think it's transmission related.
The car will sometimes boost to 1.1bar at 3000rpm but as the revs increase, boost drops rapidly to 0.6-0.7bar.
On the over run I show -0.5bar now.. and at idle -0.4bar.
I've been under the car and checked all the vacuum hoses. They are in good condition and secure. All the pipes connecting the turbo are in good condition and are secure. The wastegate actuator is fairly new and is properly connected to the wastegate. The dumpvalve is also fairly new piston type from Forge and is working properly.
What could be wrong?
I've got a horrible feeling that one of my problems (i.e. the groaning noise under boost conditions) may perhaps be caused by a bearing letting go in the turbo..
