1 - 11 of 11 Posts
So, is that 393 or 383 peak- and is it at the road wheels or flywheel? Anything changed since the last run?
393.1
Cam Timing
(running without keys in the sprockets and my fingers crossed)
other plot was last time
less torque than before but better delivery..
quite pleased
The big question is, are you happy? Or do you think you'll be doing other engine mod's? By the way, one last question, what's your clutch set-up?
Nice numbers, ylee coyote
Some questions:
1. What are the specs for you turbo ( wheel diameters, turbine A/R ) ?
2. Are you using tube exhaust manifold ?
3. Which injectors ?
4. Is head ported ? If yes, do you have flows with different lifts ?
5. Are you satisfied with drivability on street ?
6. Original hydraulic valve lifters ?
7. Which cam ( noticed that you have SP:s adjustable cam spr...) ?
8. Std valve springs ?
9. Which fuel pump ?
10. Did you measured EGT:s and AFR:s ?
11. Have you measured acceleration between 100 - 200 kph ?
Discussion Starter · #11 ·
further work planned
tubular manifold and downpipe
vernier cam sprockets
final dyno session to set up for max power...
Turbo is Garret gttb 30 ..I will have to check the a/r and turbine size
630 cc injectors (or there abouts)
head is ported with oversize exhaust valves (+ 1.5 mm)
No flows with lift
Cam is Maptun stg 6
Uprated valve springs (+ 30 %)
Fuel pump is 3 X standard (flow capacity)
origonal hydraulic lifters
no egt or afr's this time
when I do the cam set up it will be part of the package as well as boost
No acceleration runs till its dry here (about august !!)
Drivability ?
Like a [expletive deleted] cat (just do not stand on its tail tho...!!)
Before the cams were adjusted it had a real lumpy idle
It sounds completely normal(but loud ) apart from a high idle speed at the moment
Clutch ?
Sachs (the expensive one with everything !)
1 - 11 of 11 Posts
