Some of you will know I've had real grief with my BB turbo hitting silly boost levels (2 bar quite easily!) as it spins up too quickly for the software to react and contain it. I've been searching for a solution for a while now (slugging the software didn't help), and a while back I tried using a Dawes Device in parallel with the APC solenoid, but that didn't seem to work at all well and I never pushed it further.
Having given the matter due thought over the last few months I decided to try again and it works!
Basically you tee the input end of the Dawes in to the C line, and the output end of it in to the W line.
In order for boost pressure to rise above base, the APC solenoid effectively holds back the boost until the desired level and then opens slightly to let boost through the the wastegate. Thus there is in effect a pressure differential across the C and W ports. By placing a valve that opens at a pre-determined pressure (enter the Dawes) I have effectively capped the maximum pressure differential across the APC solenoid, and thus max boost
I soldered up the little bleed hole in the Dawes as it was not needed in this application.
There we go- a use for a Dawes/MBC that's actually guaranteed to protect your engine!
Here's the plumbing, which I'll tidy up once it's had a thorough test:
[edit] And of course, this means I should be able to get the software "de-slugged" for an extra bit of responsiveness
