Following my recent JT exhaust fitment, i have finally got round to getting a boost gauge so i can adjust the base boost. My 94 Aero has felt a little slugish recently - although not terrible so i wasn't too suprised to see my boost figures:
Base Boost 5.9PSI
Peak Boost 12PSI
My base boost seems low, but would this really knock 5PSI off the peak boost? (Assuming the peak boost should be 17PSI - correct me if i'm wrong)
I have checked my wastegate is working correctly (By removing the W hose from the APC).
My next move i think is to adjust the wastegate by a couple of turns, then reset the ECU and do a few adaption runs.
Can anyone suggest anything else i should check/adjust?
Am i correct in saying my peak boost should be more like 16-17PSI?
See this thread Base Boost - Mark advises that due to possible changes in back pressure bas boost may need to be adjusted after fitting a larger exhaust like the JT.
Mike
Hi All
Having put two turns on my wastegate, and performing an adaption run or two i am pleased to say i am now getting a base boost of 6.4-7 and a peak boost of 14.7
I am once again very greatful to all those who post on this forum and help us all get the most from our cars! Thanks All
