I have just been told from my garage that my car is not going to full boost because of balance shaft bearing sprocket/chain wear and/or incorrect refitting. This causes noise picked up by the knock sensor.Note that there is no chain noise coming from the engine. I haven't picked up the car yet,I will post more later. I do not know how the garage concluded that,I'll let you know.
What do you think? Anyone else had this problem?
Are the sprockets/chain expensive?
Do I need to remove the engine? (I wouldn't think so, but in the Haynes manual the procedure is in the engine removal section!).
In idle, every 3-4 seconds,there is a slight "knock" that can be felt inside the car. However, I think this has been reported by many of you in the past. Is it normal, or is this more evidence?
How hard is it to replace the sprockets and chain? Could it be done in a day?
Sorry for the long questions...
Harry
1991 CS Carlsson auto with 100k
Harry
