Pete
New belt, auto tensioner, tensioner wheel and rear idler wheel fitted. Runs much quieter now. I have just checked my owner's manual. There are 2 diagrams/pictures there but not mine! I may have been misleading you slightly. My car was registered on 19 Nov 1991 and is a model year '92 so should I be refering to it as a '92?
The diagrams in the owner's handbook show a single belt with a manual tensioner or a 2 belt set up with an auto tensioner. Mine the the last of the three permutations which is; Alternator, Rear idler wheel, PAS, tensioner wheel (with Auto tensioner), Crankshaft, Water pump and a/c pump all on one multigroove belt!
These 2 links tell the story:
http://quasimotors.gar.net/beltview.htm
http://www.saabnet.com/tsn/bb/9000/index.h....html?bID=60738
LPG. I bought my car in Mid Nov 00. It had been fitted with a Landi-Renzo lpg conversion (Italian maufacturer) in July 98. The firm that did the conversion are no longer trading, for non-lpg reasons. The sole importers of my system are Eco Gas systems ltd at Bidford-on-Avon
http://www.ecogas.co.uk/index.htm<br />and they have many trained and approved fitters throughout the country. The system fitted can be viewed at
http://www.landi.it/<br />with my particular system at
http://www.landi.it/catalogo/gple/sgpl1e.htm<br />which comprises a 85 litre tank in the boot behind the rear seats which can still fold down (the SAAB boot is huge) which will take 68 litres (80% of tank capacity) to allow for expansion. Toroidal tanks (doughnut shaped) in the spare wheel well are now available. There is a filler neatly plumbed into the bodywork. Under the bonnet is a vaporiser (reducer) that takes liquid lpg and turns it into gas (engine coolant routed through the vaporiser keeps it from freezing - expansion of gases!) and the gas is injected into the inlet track. The flow is controlled by a stepper motor which is managed by the lpg ECU, which uses the lambda probe and other sensors to control the flow of gas. There is another box that emulates the action of the injectors so that the orginal SAAB ECU is happy. On the dash is a simple 2 position switch - petrol or gas which you can change over on the move or when stationary. There is also a 5 led gauge (4 green, 1 red) as a crude indication of the gas remaining in the tank.
When selected to gas the car starts on petrol, and after about a second automatically switches over to gas (when the lpg ECU senses that the engine is running it opens the various gas solenoids).
I have driven 2,300 miles on gas (I think the car has done about 18,000 miles on gas before that). No problems! One bonus is that the car heats up in the mornings a lot quicker (lpg doesn't need a choke to enrichen the mixture on start up).
I can't tell the difference between lpg and petrol in terms of performance despite switching back and forwards on a number of occasions. The engine is slightly quieter on gas and the exhaust is certainly a lot more pleasant (a bit like a gas heater).
There are 610 lpg outlets in UK. see
http://www.lpga.co.uk/fr_ab_lp.htm for more details. Prices are typically between about 36 and 42p a litre.
The tank gives a range of about 240 miles before needing a top up. There is 74% of the energy in a litre of lpg compared with petrol so direct comparision of mpg is not very helpful. Pence per mile is. I have averaged 9 to 10p per mile vice on petrol 13-14 p per mile (the petrol cost is an estimate as I still have a full tank of petrol from when I bought the car) - its uncanny looking at the full guage after 2,300 miles. What is your petrol mpg? Are you manual or Auto?
An advocate of lpg is Tim Hewett who has an excellent web site at
http://www.dotslashslash.com/LPG/LPG.htm with plenty of links to more info. He has a picture story board of his set up (lovato) but the principles are very similar to mine.
I know of 3 other SAAB 9000 lpg conversions (one being a Griffin). The latest SAAB owner's club magazine has an article.
I think my car's lpg mpg could be better and I am going to get it gas analysed and the lpg ECU checked out on a laptop next month.
The only down side was that the original installation was not upto the Code of Practice standard (COP 11) and as a professional engineer I couldn't let that slide. So it has cost me 16 hours labour and some more bracketry to make the tank location, lpg fuel pipe to engine bay and vaporiser bracket top line. Annoying to have to have it done but my peace of mind is much better.
Overall I am very happy. The car is a very different beast to my previous Carlsson. 'More a mature businessman's express rather than a turbo boy-racer' as my wife puts it.
The lpg industry is still new in UK (mature in Holland, Italy and Australia). There are a lot of new installer's out there and as expected there are some less than happy customers as a result. But 1,000,000 Italian drivers and 400,000 Autralian drivers can't all be unhappy! If you think about it the problem for the installer is that he has to match the ECU mapped characteristics of your car (as developed by the manuafacurers at great expense) with the lpg ECU characteristics that he is installing - some installers will be more skilled at this than others). Typical installation can be from about £1200 to £2000. Depending on your mileage depends on how quickly you will recoup the cost and make saving. My car had the bonus that it was already fitted.
Oh and a final bonus... I haven't had to queue at an lpg pump yet!
Hope you find this of interest
Gavin
'92? 9000 CSE 2.3 Turbo Auto lpg
