21 - 27 of 27 Posts
I did the genuine aux in upgrade today and it was simple, managed to get 10% discount and got it for £46. Fitted it myself in the dealer's car park (taking 5 mins as I had removed the panels, the climate control unit and freed up the head unit at home before going) and then twisted their arm for a techy to come and set it up for me on their plug in computer thing. It is great, now need to sort out the speakers. I have already upgraded to 6x9 Alpines in the rear and some JL 3 inch 2 ways in the dash. Am going to go to my car music man and see what he suggests which I am sure will be cheaper than using the original 7 speaker amp1 upgrade. He has suggested an amp under the passenger seat and 9's in the doors, will let you know what I do
Retired Administrator
Discussion Starter #22
The amp will be a tight fit under passenger seat and most likely your rear passengers will kick the connections, you can route the cables to the boot to avoid this or buy a very small amp - Vibe Litebox is tiny and is the only one I know off the top of my head.
9's in the door? They will not fit without grinding part of the door off, the factory size is 6.5".
hi got a 54 reg 93 tid want to add an amp have got the icm2 unit but ther is the stock saab amp2 connection in the boot can i use this connection to wire a speaker to rca convertor to or not plus wheres the best place to wire the amp remotes to install a vibe slick a0 2 channel amp to run vibe slick 6x9's and a vibe slick a7 to run 2x slick 15 subs i know i only need one rca convertor as i can use the rca out on the vibe slick a0 amp to feed the imput into the vibe slick a7 amp. have been told that if i wire the rca convertor to the stock amp plug i could blow the system is this true or not any help would be much apriciated
Premium Member
http://www.saabscene.com/forum/threads/131520-SAAB-AUDIO
Pictures of where to get remote on for amps here
The kinda power you'll be running will require a separate feed from the front so there's no need to use amp2 connector
As you have wiring for amp 2 I'm guessing you have amp1 fitted (under passenger seat) if so I would use the output of amp1 into a speaker - line converter (low - high impedance converter) for the audio
Premium Member
Gonna have to read all this again, as I'm really finiki bout dash damage (Butter knife) ........ I have nail scratch marks on my glovebox opening button & they drive me shitless........ I'll tell you all about my mental disturbance re-Tech 2 & line in if you like ........ Via a written report .......
Lets not get on about the cocky awful semi silver trim on the auto gear/function selector ....... Sheesh I'm beside myself bout that ....... Really I am ..... I mean ..... Whoooooooo The Fk ?
HELP! I cannot find anywhere to ask a question, but this thread might be able to direct me. My SAAB radio died and I replaced it with a Pioneer unit, installed by a specialist. All of the audio warning sounds do not now work. Is there any fix to this?
21 - 27 of 27 Posts
