is there any tricks to getting the turbine (exhaust) housing to free up from the center section?? i am doing a custom turbo setup on a cavalier and i am using a saab t3 turbo but need to rotate the turbine housing so that the oil drain is pointing down toward my oil pan but cant seem to get it free. Thanks for any suggestions.
Nick
Do you mean undoing the bolts or actually separating the housings?
I've never split a turbo but I would imagine heat from a blow torch/oxy acetalene torch may well be needed to swell the housing and seperate the rust.
HTH
Neil
