does anyone know where i can get a converter plug so i can use my 1991 built in amp with a the sep radio/cass/cd from a 1995 9000, the 1991 has less pins than the new one and i dont want to start hackin the wires around.
thanks microcat36
I've no idea about what the parts are but if you are prepared to make your own cables, either RS or Farnell will supply practically everything connector wise.
Their websites are
http://rswww.com/
http://www.farnell.com/
both of which have full lists of their catalogues.
However you may need to plough through the websites for some time as there is an awful lot in there....
You may need to get a number of the connector itself, usually moulded into the plastic somewhere.
Also after a quick browse (you can tell I've got a presentation to write ) I found this
http://www.clarionworld.co.uk/install/saab.asp
Do any of those connectors look familiar?
John P
the power cable i will be able to work out but the amp cable on the old one is a round plug with 7 pins in it the connector on the new one is rectangular with 8 pins no way of knowing what goes where seems a shame to have to junk the old amp as it is ok but without a diagram i am lost, no use with rewiring anyway
Yes, blind electronics is never much fun, and there is always a chance things get hooked up back to front and start fizzing (guess how I know this.... )
Sorry I couldn't help....
John P
worked out the bottom of the 2 blocks it is the power as everything works ok just no sound does any one have a diagram for the plug for the amp or would saab have a adapter plug for the two models.
