I have a 60 reg saab 9-3 tid 1.9 turbo edition.for the last few days the amber warning light on the facia for the passenger airbag stays permanently lit during running. it says nothing about driver airbag, jus reads passenger airbag on. I read the manual and it told me to turn it off with the switch in the drivers side pillar. it now says passenger airbag off, but is still lit up all the time. any help please. tom
Have you had a passenger in the front the last couple of days ?
If not then I think what happens it dose a system check then the airbag light will stay lit wether you have turned it on or off .
As long as you have not had the contact service message on the Sid and the airbag light on the dash panel then I think you are ok .
Well that's the way I read it .
Discussion Starter #3
thanks lizard, I have had no message on the sid. You said. "airbag light on the dash panel" is this were the speedo is. as mine only shows on the facia next to the sat nav on the right hand side. thx again. tom
