Hi
I have a problem with the air con on my 1995 9000csi .With the air con turn on ,it makes the engine miss and run abit rough .This happens whether the engine is under load or not .It seems to be makeing the engine run lean ?
any ideas .
does the car mis under load with the a/c off??? if so then i would be checking the DI and spark plugs, as the A/C could be putting enough load on the engine to cause ignition problems. other than that
