1 - 1 of 1 Posts
Has anyone have any idea how to take off the Air con compressor Pully/clutch.
The reason. The Drive belt decided to shred itself last Sunday (only two months old, but not fitted by SAAB or myself)
I have replaced the belt (use coil spring ommpressing tool on damper) However the old belt has broken the electronic switch on the back of the pully clutch.
There is a blue wire to the top of the switch, no problem to disconnect. However from the bottom there is a wire that is soldered to the clutch body. I can't get the switch off to see if I can repair it because of the lower wire.
If I can remove the pully clutch I might be able to.
Any suggestions?
1 - 1 of 1 Posts
