Hi new to site and saabs
I have a 9-3 tid 1.9 convertible it had a water leak getting in from under the scuttle panel where the filter is ( now sorted ) my problem is the floor passenger side was soaked so I took the seat out to dry it unfortunately (being an idiot ) I forgot to disconnect the battery now the air bag is coming up on digital display my question is does anyone in the Devon area have a tech 2 so I can turn the fault off
Sorry if this is long winded
You can try to disconnect the battery cables and put them together it cause a small current who erase warning message.. Then reconnect and try.. If you have some issues it caused by issue at seat connections..
Don't do as above, you can try the disconnecting the battery ( make sue the key is not in the ism through all this process )
Leave disconnected for half an hour then reconnect , put each key in the ism for 10 seconds to resync then re-set anti pinch on windows .
Another known problem is there is a little micro switch on the inner seat rail that becomes de-tached very hard to see but it's at the front of the seat rail make sure that is still attached .that is for the seat position sensor , so it knows where the seat is in relation to the airbag if airbag is deployed .
