Having got half way through my quest to check and/or fix the boost on my '96 aero, I have a couple of questions ask... firstly I 'll tell you where I'm at..
1) The car boosts to the top of the yellow section on the boost gauge - no further - i.e. never into the yellow/orange section.
2) Checked the wastegate R pin (OK)
3) Checked Wastegate rod (can move it by hand - so seems OK)
4) Changed plugs (old were 1.3mm - new are 0.9mm)
5) Changed fuel to Optimax and did a calibration run. - Although I only took the fuse 5 out for about 1 minute (enough?)
6) Checked for vaccum leaks - all hoses in good nic - still potential for a leak somewhere I suppose.
7) APC solenoid is 3.1ohms on pins 1-2 and 2-3 (2 being the middle)
As a result of the above, the car now pulls better low down and is much smoother but top boost is the same as stated.
next Steps:
1) Calibrated boost gauge is on order - looking for 1.1bar on full boost - this is really the key test.
Question:
I want to test the APC solenoid - and the information I have is to disconnect the hose marked 'W' and go for a drive (assuming I dont need to nip the end of W?). If I get lots more boost then it suggests that the solenoid is sticking. If not then it's probably something else....
I'm also a little concerned about boosting too far!
I've read the thread below this for info. - along with about 30 other similar threads, but still keen to hear experience of others..
PS - to me the car goes rapidly, but I believe that base boost only is still pretty quick.
next Steps:
Question:
