Hi, Guys my old motor is on its last legs again, so I have reappeared after a long absence.
I never did get the #6 PVC change done and it sems to have come back to bite. Based on the behavour of oil light it seems like a case for doing the Sump Drop and the final PCV update. I've been reviewing the more recent discussions from when I last visited the subject in detail (probably late 2007 or earlier).
I hoping for a reply to two to check I'm going in the right direction. Also we are a one car household so its hard to go and get something if I'm not prepared. Mine's a 04/1999T 9-5 SE 2.3t so part numbers match this I think.
For the Sump Clean key points seem to be:
For the PCV change it seems a good idea to replace the 3 hoses not in the upgrade kit:
For the Oil Change:
Thanks.
- Loctite 518 to seal it back on (cheaper per ml than the saab packaged version).
- Oven cleaner to get any bad gunk off.
- O-ring for oil pickup tube (91 38 009).
- Uncouple Exhaust downpipe
- 80% release subframe instead of forcing engine/gearbox aside.
- Vent Kit (55 561 200)
- 3 Hoses (55 560 445, 55 560 463, 93 999 73)
For the Oil Change:
- Shell Helix Ultra 5w40 Fully Synth as car has had a poor life. (Alternative to the 5w30 saab, gm, mobil1 recommended for tighter engines).
- Oil Filter (93 186 554)
- Plug and Washer (91 329 29, 91 329 37)
- degunk bottom of engine while exposed
- degunk inside rocker cover
- rocker cover gasket to reseal (88 220 41)
- clean out turbo hose?
- new o-rings to refit turbo hose?
- have seen mention of cleaning the intercooler - don't know if dealer did this when it had its previous 2 turbos.
- My general questions above after the sump/pcv jobs.....
- Is it useful to extend the clean as much as possible? It is probably a sad engine....
- I am not (yet) clear which turbo hose(s) to clean and what o-rings that needs to refit.
- In terms of cleaning the top/bottom of the engine is there anything best used for this?
- Will anything remove varnish if I have any (and does it matter anyway)?
- I dare not pre-flush the engine as the current behavour suggests a bad sump screen already. Would I do better to refill now with the cheapest ACEA/A3 full synth I can find and then add a rapid flush in say 3k miles and repeat the sump drop? Or what?
- Any additives/flushes recommended for either a (delayed) flush & second sump drop, or to get the engine cleaner (say of varnish) over time?
Thanks.
