hi
any idears what type of actuator to get and wear from? .wear it will fit with no grinding or cutting and what sort of spring size i need??
for a saab 9000 aero auto full jt cat bypass jr fillter
You should go for a spring that's just a little below the base boost you are running, say 80%. That way you are sure it's adequately holding the wastegate shut without having excessive preload.
so ok my saabs a 9000aero auto runing 0.45 bass then with full jt cat by pass and a jr fillter. would a 0-10 psi spring do also i do plan to upgrade the ecu ????????????
