Ok firstly ... stainless steel is not just one metal. There are many grades.
Type 304 stainless is what's most commonly used in exhaust systems. It is the BOTTOM OF THE LINE stainless steel used on most exhuasts. (Type 302 etc are rarely used.)
321 stainless steel is a step up, and designed for the high heat world of turbine exhaust stacks.
Here are some facts on both:
AISI Type 304 Stainless Steel
Material Notes:
Austenitic Cr-Ni stainless steel. Better corrosion resistance than Type 302. High ductility, excellent drawing, forming, and spinning properties. Essentially non-magnetic, becomes slightly magnetic when cold worked. Low carbon content means less carbide precipitation in the heat-affected zone during welding and a lower susceptibility to intergranular corrosion.
Applications: beer kegs, bellows, chemical equipment, coal hopper linings, cooking equipment, cooling coils, cryogenic vessels, dairy equipment, evaporators, flatware utensils, feedwater tubing, flexible metal hose, food processing equipment, hospital surgical equipment, hypodermic needles, kitchen sinks, marine equipment and fasteners, nuclear vessels, oil well filter screens, refrigeration equipment, paper industry, pots and pans, pressure vessels, sanitary fittings, valves, shipping drums, spinning, still tubes, textile dyeing equipment, tubing.
(Notice they don't mention exhausts of any kind as an application. Doesn't stop people from using it for them though.)
Corrosion Resistance: resists most oxidizing acids and salt spray.
AISI Type 321 Stainless Steel
Material Notes:
Titanium-bearing, austenitic, chromium-nickel steel. Stabilized against carbide precipitation and designed to work within the temperature range where carbide precipitation develops. Similar to Type 304 except Ti content helps prevent chromium carbide precipitation resulting from welding or elevated temperatures. Stabilized at annealing temperatures between 950-1010°C (1750-1850°F). Resists scaling and vibration fatigue. Applications include aircraft exhaust stacks and manifolds, chemical processing equipment, weld equipment, jet engine parts.
Most exhaust companies choose the 304 simply because it's slightly cheaper.
304 s/s is also the culprit for stainless steel tube header's reputation for cracking on turbo cars. Were those tube headers made of 321 they would not crack.
I've no idea if anyone makes 321 stainless exhausts for Saabs, but if you're going to a custom shop you could look into buying some tubing. I believe
www.aerospacemetals.com sells tubing, though you'd need to get a quote to find the price. They also sell Nimonic and Inconel alloy bits and pieces. Not useful for downpipes, but if someone wants to make headers, Inconel would be a top choice.
Anyhow ... just my two cents for the convo.
Dubbya~
