My drive belt is starting to squeal on the odd occasion, can anyone tell me where the adjuster is to tighten it up is please ?
97 9000 2.3t cse Manual
Many thanks
Many thanks
Its easy (IMHO) to fit the new damper pulley combination yourself, no special tool required. Well, special tool for getting the belt on and off but a suitably placed tyre lever does that job. Having done this job a few times I can now do it on my own - but I have got long arms.As for the belt tensioner don't be tempted by the £50 hydraulic tensioners that some specialists sell, they are simply the hydraulic ram part of the unit. If you haven't got the redesigned unit on the car get a new one from Saab. It will set you back about £120. I learnt from experience when my repaired one snapped and I drove over it (with new belt) in the New Forest. You really need it fitted by a dealer with the special tool, the Haynes manual suggestion doesn't work for replacing the tensioner, just a belt. Get the dealer to fit all new bolts as well, mine cracked under the strains of the old damper.[/b]
