Now its hot out there I've just realised that the acc is not blowing as cold as it used to and not quite cold enough for my liking. Whilst it is cooling a bit (i.e cooler than when using on econ) I'm sure something isn't quite right. I have had the car about 2 years now and guess it maybe time to re gas. Does this seem likely please and how often should this need doing
I beleive all systems whether Saab, Mercedes, Honda etc leak a little somewhere and need a top up of gas every couple of years. In fact I think the recommendation with Saab is every 12 months.
It's worth shopping around though, my last top up cost me £45, and then I spoke to a refrigeration engineer who said he does it for £15!!
I beleive all systems whether Saab, Mercedes, Honda etc leak a little somewhere and need a top up of gas every couple of years. In fact I think the recommendation with Saab is every 12 months.[/qb][/b]
Not really. In my ownership of a 9000CS since 1995 in Hong Kong where the temp. exceeds 30C for 6 months of a year, any leak of refrigerant will be very, very noticeable.
Yet I only need to refill the stuff twice in these 8 years, and that's because something broke: the receiver and the metal hoses running to/from the compressor. Otherwise the system is air tight and won't leak.
It may depend on its frequency of use.
An air conditioning system seems to like constant use to keep it leak free.
Hong Kong is a bit warmer than Herts and will be used a bit more often (probably daily).
Some systems leak a little, some a lot, some not at all.
If it's cool but not as cool as you'd like it a top up will be in order and could probably last a summers use or more. Just one question,how old is the car? If its got the old R12 refrigerent then it's now not availible (CFC's and all that) as far as I know. The later cars have a system filled with R123 (I think). My local specialist does conversions as it's not as simple as just filling up with the newer gas.
By the way leaks can be found by introducing a dye into the system to show up where the gas is coming out from.
HTH.
Nick.
My recent bad news is that having had to have mine topped up three times in the last 9 months the garage has now found the leak - in the compressor. So its £300+ for a replacement.
Originally posted by Bunsen 248 (Gassy got lit up):
[qb]the garage has now found the leak - in the compressor. So its £300+ for a replacement.
[/qb][/b]
Asuming the AC system was in good working order prior to all the R12 leaking out, conversion is quite simple and straight forward..
Change compressor oil
New drier
change valve ends on compressor
and in an ideal world replace condensor, but thats not essential.. top up with R124a job done..
edited for carp spelling. Only 5 words and I still get it wrong
[/qb][/b][/quote]errrmmm yeah...
