Does anyone find that the auto temp selected is fine for a while but after a while changes (by usually getting too cold). I thought being climate control it should stay fine and adapt to changes outside without me noticing a change. Perhaps I expect too much!
JD, thats the theory - the tempreture sensor(i.e. circular grill about size of 10p in fascia on r/h/s of ACC control panel) and sunlight sensors (central on dashboard) are suposed to enable the ACC to hold tempreture constant. But it doesn't do a perfect job, although I have never know it to get progressively colder for a set tempreture.
Check that the aforementioned tempreture sensor is not clogged with dust as they are prone to do. (i.e. give it a vaccume clean!). Otherwise a recallibration may help by pressing top left hand corner button and lowwer right hand corner button simultaneously (from memory - or check in hand book). If their is a fault the display will show 1 to 5 depending on number of faults in system.
