ACC (or A/C) will definately cause the front screen to mist up more than a normal car.
Once the aircon pump has been run, water will collect on the cooler (i.e. because it dehumidifies the air, as well as cools it). So, when aircon is turned off, the air passing through picks up this water which then condenses on the windows!
I would hazard a bet that this is what you are experiencing Adrian!
As I generally run my car without the aircon on, the windows do NOT normally mist up. But if I run the aircon for 10 minutes, then turn it off, the front window will almost always steam up - certainly for the first minute or two. The situation is always worse if it is raining or there is high humidity levels outside. If the outside air is quite dry, the misting window effect should clear quite fast with the aircon off and the fan on a medium to high setting.
The above is 'normal' for Saabs with A/C or ACC, and most aircon systems on cars.
But if there is loads of water vapour, and it smells warm and muggy and like antifreeze (cos it is!) then the normal cause is the heater matrix leaking. Apart from the smell, a heater matrix leak can often be detected because the aircon (when turned on) takes a lot longer to clean the mist from window.
If the recycle button is on, or the flap is stuck, it will also cause general misting of all windows to occur - but without the antifreeze smell (i.e. heater matrix not leaking). But such misting normally takes alot longer to build up than if caused by water having condensed on the aircon cooler (due to aircon), or a leaking heater matrix.
