Help
9000 CSE 2.0i For no apparent reason ACC blower fans are operating on full blast all the time. Air con and hot air still operate when temp is adjusted. I have tried recalibration to no effect. Any ideas please!!!!
Thanks for the advice dave_H . I have taken the fuse out......I can hear the radio now!! I will have a look at the w/e. Is the job the sort of thing the average owner could do or one for the specialist? I would appreciate the name of your supplier.
Many thanks
Hi
In my case the fan speed controller was mounted on the side of the fan unit ('91/'92 CDS). The fan unit is under a plastic cover at the back of the engine bay. Remover cover, one screw is longer them the others, note. You have to remove the metal bulkhead/divider, bolt on RH side, screw on LH side. You may have to remove hose from clips on panel.
Lift panel out from RH side first.
ID fan housing, controller is low down on side. Remove 4 pole electrical connector.
Remove control unit via 4 torex screws.
Power transistor is on PCB labeld - '2SD1525' available from Dial Electronics, Burhope Rd, Washington. NE38 8HZ Tel: 0191 417 7003 FAX : 0191 417 7053
I think they were about £1.50 each +pp.
Hope this helps.
D
