Hi everybody,
When I bought my 94 Aero about a year ago I realised that the TCS light was on for a long time. At this forum I read that is this light was on for more than 5 seconds I could find that the brake fluid had to be replaced.
OK, I told my garage to test the fluid and they told me it was OK, no replacement needed. About a month ago I had to replace the ABS pump (electrical part) and the ABS pressure switch. That could drive my pocket broken if I had not found second handed parts at www.partsasap.com (Andy is a great guy). Once the parts were replaced the TCS light turns off in about 3-4 seconds.
These things had me think that it coukld be a relationship between the long lasting TCS light and the gone pressure switch. After asking some mechanics of confidence, I can tell you that if your TCS light is on for more than 5 seconds and you have your brake fluid with correct properties you should chek your pressure switch... if its worn your ABS pump has serious difficulties to reach the working pressure and works more time than needed and this could brake your pump.
I can tell you your pocket doesn´t want to suffer a broken ABS pump.
Greetings from Spain
